Miles Porter
Everything is fantastic although I am not sure the Leisure battery is performing as should. The battery seems to drain quickly when not on hookup and aux heater is running - this morning drained from 100% down to 70% in 20 mins.....surely than can’t be right? We want to go off grid for couple of days however at that rate (if we want to stay warm) battery won’t last more than 2 hrs. Vinny is just 5 weeks old and has been on hookup to charge couple of times - charges as expected when ignition switched on and when connected on hookup.....retaining charge seems to be an issue. When aux heater is on <2A being used and 12.5v charge on battery - after 20 mins running the battery shoots back up to 100%. There are no other usb/lights in use.
Any advice will be appreciated.
