Leisure Battries 75 amp /h x 2
Little owl1963
Little owl1963
Walsall West Midlands
T6.1 Ocean 150
The cali ocean t6.1 comes 2 these as standard , is this enough ??
would it be better to have higher power ones of 110 amp /h or 150 or would this overload the system ??
Would it give you much difference/ advantage in power off grid , or would it overload system an solar panels if fitted ?
Or is 75 amp / hr the best option , or were they just factory fitted that size cause cheaper ?
Battery capacity makes no difference to power output. The problem is that bigger capacities require more space. Lithium batts solve this to an extent but open up a whole new can of worms on replacing the charger and integrating them into the system which is why most people needing more amp hours go for stand alone powerpacks like Ecoflow, Anker Solix or Bluetti.
Thanks never thought that more space , yes power pack good option .
"Is this enough" - yes and probably more capacity than the average campervan. Certainly our Cali lasts longer on batteries than any motorhome or campervan we've ever hired in the past). If you really need more power, either look at solar or use hookup.
thanks for that , least no got right batteries thanks
