L
LimpModeVic
- Messages
- 6
- Vehicle
- T5.1 se 180
I HAVE A VW 2004 T5 MULTIVAN, DIESEL, 2.5, 170PS
With the Limp Turbo problem. Between me and the VW Repair shops in the entire state, we have replaced the entire vacuum system, turbo (refurbished), intercooler, air filter and an oil change
but the limp mode problem still exists.
Originally the limp mode problem was there but then the turbo started to go bad when it started squeezing and whistling. So I replaced that with what is supposed to be a refurbished original. After replacing the turbo, limp mode still exists when the engine is under high stress or pressure.
I took it to the shop for diagnosis. The computer reads with zero failures. That is what lead us to start looking into the sensor system. We systematically replaced all sensors dealing with the air system and the turbo. But replacing any sensor lead to no change in character.
I also replace the EGR unit, not just the valve but the whole housing.
With no change there that lead us to do a pressure check of the system but no problems were found. While looking a little closer at the intercooler, we noticed what looked like an oil leak around one of the vents so we removed the intercooler and put it under water for testing and found that it leaked air bubbles. This fault was not found in the original pressure testing. So today we have replaced the intercooler with a new one. BUT the engine still goes into limp mode after some time. Of course if the engine is turned off and then back on, it is reset and all is fine until it does it again.
The only two system that we have left are the electrical sys and the turbo itself. We are considering replacing the turbo with a brand new one, but this refurbished one should work just fine as it functions just fine up until limp mode. We simply have no other ideas of what to do.
I have been reading about this problem all over the internet and every single individual has a different answer to their problem. I have actually tried every one of those answers to no avail. VW has even called other partner shops in the area whom also have no answers.
The only other known fault in the entire vehicle is a bad oil sensor and a few parking sensors that need replacement.
Does anyone have any ideas that we have not tried?
