Wow that was quick - I was being blown away by the hi tech t5/6 comments.
Its 2003, LHD.
Qs: heres a few questions to start off.....
Need 16" steels for winter tyres - is that possible as I have the tyres on t5 rims (i know i can't use the rims)
How do you get at the leisure battery.
Open the boot and it's on the left hand side under where the bed sits in a little cabinet.
Used it away last week & had a flat battery when tried to drive away - used normal radio - could that be the cause? If so how can I avoid that hassle - other than taking a little transistor.
The radio should not run down a car battery (especially as your vehicle I guess is a diesel and will have a heavy duty battery - either you have an open circuit draining your battery, or the battery is shot.
Should diesel heater blow from both black vents? Only one seems to work - how can I sort this?
Should the cooker burners be an ignition option to light - theres a small spike behind each burner.
Roof bars - needed to carry surf boards, was hoping for an option that I could slide the bars in a rail type system - any ideas of the best option as I'd like to be able to remove bars easily too.
Bike rack - I have an original rack but not 100% working - can I get parts, e.g. the lockable winder is seized, the short fixing arm also seized, other bike fixing arms not present, the one rail for a bike to sit in has been ripped out - can I get an original replacement..
Night heater seems to be full on and not able to vary temps - any ideas how I can test it etc.
My T4 Cali had a little thermostat like a dial.
Symbol for clean water tank is showing full when I know its empty - solution please?
Either ignore it, or try to free up the sender unit ( I think it has a mechanical arm with a float - which triggers the sender unit)
Any english handbook download versions as mine is german.
Yes I found one possibly on The Samba.com I will see if I have a copy on an old pc and let you know.
How can I get to the small grill near the front bumper which appears full of moss.
Alarm immobiliser - its remote key operated and has what appears to be built in sensors, but not sure about if alarmed or has immobiliser. I've researched a few places but no conclusive answers.
