Jon Hermansen
Hi all. After a couple months after we bought our T5 cali ocean 2007 i found out the rear leisure battery is missing. Both battery and cables are removed. Old owners didnt know anything about it. So i bought two new agm 80 amp batteries to replace both leisure batteries. What power and earth cable size should it be from the under seat battery to the one in the back? And a 75 amp fuse is the correct one to have on the rear battery pole right? And last question should the one earth cable from the shunt under the fridge connect to the negative on the battery? Thanks and a happy summer to you all
