Vantastic2
Bit of a shock when I took my cali for it's first MOT back in March to be told it failed the MOT due to tyre wear on one rear tyre !
There was under 20,000 miles on the tyres but the inner edge on drivers rear side exposed the tyre fabric showing steel make up and it was less than 1 mm wide around circumference of the tyre approx. 25mm in,i did not spot this as I have mud flaps. The other tyre was going too, so played safe and had them both changed..
You cannot have any tracking done to rear wheels which is so annoying, back in 1977 (showing my age now)
I had a car with same problem but could and did ' shim ' the wheels which would align them as you would with tracking on front wheels !
So it would be interesting if anyone else on here has had the same problem ! might be best if one can remember to have wheels alternated after say 10,000 miles time ?
( sorry taken so long to do this thread as my Mum was in hospital-stroke,now in a home )
