Naked Door
California_Clarky
California_Clarky
Southampton
T6.1 Ocean 204
I am looking at fitting sound deadening to the front doors of my Cali and wanted to plan how I would do it before removing the door panels - does anyone have pictures of the inside of the 61. Cali doors with the door trim removed
TIA
i'm about to do it on my T6. mixed ideas suggest it's better to stick it behind the window regulator on the metal skin which is tricky. some have good results sticking it to the door card and refitting it straight back on. thats easier obviously. try u tube
Might be some pictures on Alpine speaker thread, thinking of buying these speakers myself and will fit dodo mat at same time
T6, but I think it will be the same as the T5, up to the T6.1.
First you have to remove the door card, then you will have to take the window apart from the regulator. Then undo all the 10mm bolts, undo all the wires, undo the lock, and take the plate with lock out completely.
Nice job, but a bit hard if you don't really have the knowledge. Maybe someone posted a film on u tube?
Yes. You gaffa tape the window shut and lower the regulator down out of the way watching for the bolts as they pass the access holes.
TIA
Fitted sound deadening to my T6 Ocean front doors. Did it by removing the speakers, which I was upgrading. Full access to the outside skin not necessary. The biggest pact you can fit thought this hole is enough to change the doors harmonic frequency
L
Lost in the Forest
L
California_Clarky
California_Clarky
California_Clarky
HowieDog
5K
reserves
reserves
