Sorry Now Sold Oasser Car Boot Organiser Trunk Organiser Collapsible Waterproof Durable Multi Compartments with Sturdy Base Hook&Loop Fastener
PeterMcAlea
PeterMcAlea
Bangor, County Down
T6 Ocean 204 4Motion
Used, excellent condition. Oasser storage bag. Posted from Northern Ireland. Fits perfectly under bed section of Ocean in boot. £25, plus additional postage. This will be £8.05 to the UK Mainland, First Class Signed for. I have two of these items available.
  • Solid & Sturdy Construction: If you are looking for a firm and sturdy car boot organiser, Oasser Trunk Organiser is definitely one of your best choices. Oasser car boot organiser is made up of 1680D waterproof Oxford Cloth. The lining of the surface cover, side plate and base plate consist of 5mm density board and pearl cotton. It is so sturdy that you can even stand your feet on the trunk organiser.
  • Waterproof & Durable: 1680D waterproof Oxford cloth makes it easier to clean, which it is durable for use. A special Aluminium Alloy Handle comforts you and won’t break when you need the car boot organiser.
  • Detachable & Collapsible: The size of the car boot organiser is 60x35x30cm. It composes of 3 compartments for you to sort out your items. If necessary, you can remove the two moveable plates to achieve a larger space. The trunk organiser can also be folded as large as a normal laptop bag.
CampervanBits
CampervanBits
CampervanBits
