scimmiamagia!
The warning light that suggests something is wrong with the Catalytic Converter keeps coming on.
VW Service keep finding a 'fault', fix it but with a day or so, the light is back on.
The van drives absolutely fine as far as I can tell (still fairly new to them so not sure what 'normal' is).
However, I do know from previous VWs (and my Mini) that a persistent light means battery.
There is what looks like a DOT number stamped into one of the terminals. 4717. I assume that's week and year of manufacture?
It's a Varta battery.
If so, it's probably nearing end of life.
I have the ctek mxs 5.0 charger for when the van hasn't been used or won't be used for a while, so will see if that makes any difference but i suspect I am simply delaying the inevitable.
