![Lizzie](/data/avatars/m/38/38589.jpg?1721417351)
Lizzie
My GC 600 has not been used for almost a year as I have imported it from New Zealand. When I started her up I found that the Central Control Panel (the screen next to the toilet door) is malfunctioning. It comes on ok, ie all buttons are visible and can switch between them, but it will not allow me to turn on lights, adjust heating, and says the battery is flat, when it is fully charged (tested voltage and it is 16v). Tap works ok as does fridge, so I do not think there is a power problem. Have tried turning off the main battery isolator switch (in cupboard with fuses) to reset, but no improvement. Could it be the way it get the information needed to display?
Has anyone else had this issue?
