P
Paul_Sheena_Moseley
VW California SE / Ocean Pull Out Rear Boot Drawer for T5, T6 & T6.1
£300
Link to product and manufacturers description below.
VW California SE/Ocean Pull Out Boot Drawer T5, T6 & T6.1 - Free Fitting if you collect from us - Give us a call and book in!
Revolutionise the boot space in your SE, Ocean or Cost with our pull-out boot drawer. You can load the van with ease and find items easier. Built using a strong 3mm aluminum tray secured to the van’s rails it is capable of holding up to 100kg. (although we recommend a maximum of 80kgs) The Drawer pulls out and locks into position and is very easy to fit.
CNC Machined to a high standard and finished with grey powder coating for durability.
Very sturdy heavy-duty rails that lock automatically when extended.
Attaches directly into the rail system of the T5 / T6 & T6.1 (T6.1 you need to move the bench seat forward by approx 5cm)
Protective tape is attached to the base of the tray to avoid scratching the floor also a non-slip mat can easily be inserted into the drawer.
Simple and lightweight.
Easy to fit.
Overall dimensions including thumb latch – 100cm x 78cm x 7.5cm = 13 kgs
Drawers internals, 93cm x 63cm.
£300
Easy to fit.
