PeterMcAlea
Cali-Wrap
This insulated easy to fit wrap comes in various colours to make your California stand out from the crowd. It provides full black out for the roof of the California (With the T6 light is often an issue) and is also completely reversible with a reflective silver on the inside for the sunnier climates. As well as keeping the upstairs nice and warm we have also noticed a slight reduction in background noise from the campsite.
Fitting is a simple as wrapping the screen around the roof canvas of the California and fed behind the mechanisms and struts of the roof. The Cali-Wrap must be removed when lowering the roof and we have found that a small plastic stool (which can be kept in the tailgate with the chairs) helps with the fitting.
Great option if using solar panels on the roof or roof bars and boxes.
Available to choose with PVC Windows, Side Vents or with nothing at all , (SE / Ocean 3 windows – Beach / Coast 3 or 2 side windows)
If vents are chosen for an Ocean – this will come with 2 side vents and 1 PVC window in the front.
Thermal Windsceen Cover
Specifically designed to keep the California warmer in the winter and cooler in the summer. This is achieved by sandwiching a layer of insulation between two layers of UV reflective polyester – reflecting heat away from the outside in the summer and heat back internally in the winter. This cover is super easy to fit – by the means of two door pockets which hook over the top of the doors and tabs which attach around the wing mirrors. The front screen also detaches from the side panels so you can drop it down in the day if extra light is required.
The cover also fits into a storage bag roughly half the size of similar products on the market!
Rip resistant,
Easy to fit and remove,
Compact and light weight
Made in Great Britain with full 12 months warranty
This item is used, but is in fantastic condition. Topper was never used. Both topper and windscreen cover are black.
£250.
The item can be collected from Bangor, County Down, or posted to Mainland UK. Cost of this will be £20 via Royal Mail First Class Signed For.
Please contact Peter on 077 31 987 851. Thank you.
Cali-Wrap
THE KEY FEATURES OF THE CALI-TOPPER ARE;
- Fully insulated
- Waterproof
- Offer a black out for the roof
- Various colours
- Easy to fit and remove
- Reversible for hotter climate
- Reduces noise
- Pack Size – 20cm x 20cm x 107cm
THE KEY FEATURES OF THE COVER ARE
Great for both summer and winter use,Rip resistant,
£250.
