bluerallye
Hi All,
I've sent a few queries out but just casting the net a bit wider.
My petrol Eberspacher has given up (usually refused to light unless leisure battery voltage 13.2+V, now won't light at all (batts are relatively new, 2 x 110Ah)) and as parts and replacement units are as rare as hens teeth *and* as i carry an underslung LPG tank, then i plan to replace with a Propex HS2211 gas heater.
Question is....what do i do with the existing fuel pipe feed from the tank to the Eberspacher pump? I assume it's gravity fed to the pump so not under a great deal of pressure. Current thinking is to simply terminate / cap-off and store out of the way.
Interested to hear any other ideas on this.
TIA
Alex
TIA
Alex
