reset alarm TPMS light
MikedeBike
swiss
T6 Beach 150
Hallo everyone!
I'm a new owner of my first Vw t6 Cali, I've change the original tires with new winter tires, TPMS alarm is ON, but I don't understand as i can reset the alarm!, can anybody help me?
there is not button to reset, e there is no push button to search on the main dashboard a menu to reset the alarm.
Thanks at all
Mikedebike
It should be under the settings menu from the MFD, type pressures and reset.
no man, thank you for your reply but, on the MFD there's no info about the tires....
You have to step through the menu's for tyre pressure setting and remember to also press confirm before coming back out of the menu.
Prior 2014 the Tyre pressure was a button but on T5 and 6 post 2015 it should be in the settings menu via
The Tyre Pressure Reset is part of the dashboard Multi Function Display.
If you have the Multi Function Steering Wheel.
Ignition On, R hand control, Press OK, Select MFD then OK, Scroll down to Tyre Pressure and press OK. Follow instructions.
You can also do this via the stalks if you dont have a multi function wheel.
If that is missing you may have another issue or they changed it?
Many thanks MAttBW, it would be possible...
this night i'll test it
