H
Hoftha
- Messages
- 4
i have a 2005 California and meet some problems with the elevation/descending of the roof. I suppose the problem is caused by the control panel.
Often when the roof is up it will not come down. If I chose "close" in the control panel, there is not any response. I found out that, when I take out the relay of the control panel and put it back in again, the problem is fixed (I did not replace the relay, just put back in the old one which is still fine)
As this is happening quite often, I get irritated and almost wish there was a crank to regulate the roof manually.
Vw dealer doesn't recognize the problem and cannot fix it.
Does anyone of you know this problem. And more interesting, does anyone know a more permanent solution the plug in/out the relay each time(which is on a stupid place under the driverseat, hard to reach......but I did a become a pro in that now........)
Thanx!
Remko
Thanx!
Remko
