RNS 510 stuck in continual boot loop
shaunchivers
shaunchivers
Bristol
T5 SE 180 4Motion
I have an issue with my RNS 510 unit where it appears to be stuck in a boot cycle. The boot screen image is corrupt (see image) and disapears after 60s before being displayed again.
I have done the usual force reboot, reloaded the software from SD card and have even disconnected the supply fuse to do a forced cold start. I had a 'Data Check' for error codes today by a garage that was sorting another issue (wheel speed sensor) which shows the 'Mediaplayer 3 OK' - I was sort of hoping it may have provided a clue.
Does anyone have any good ideas or suggestions?
Press and hold the power button for 20 seconds
Had the same issues and its software issue and can easily be sorted via an update at your VW garage.
I had a similar issue. The VW software update did not fix the issue. The whole head unit was replaced under VW warranty. Potential cost was just over £2000. If it had not been covered by VW warranty then I would have looked at an alternative head unit brand - potentially Kenwood.
Thanks for all the comments. Its now booked into VW for investigation along with some unrelated recalls so lets see what they have to say - no doubt ££.
