T
Themeparkdad
From the experience of people who have had a roof corrosion warranty repair, would you recommend having the repair, or living with the corrosion?
Has there been a poll on this, or is there a general consensus?
I have a 2019 T6 Ocean, with the following issues:
1. Front edge of elevating roof: a 10cm line of 5mm paint bubbles (where the seal had failed and rusted)
2. Where the water collects to flow into the front roof drains (under the black plastic cover you remove to clean them): a few 5mm paint bubbles
3. Panel above the windscreen: the paint has been wearing where the roof seal closes onto it (not corrosion related)
4. Panel above the windscreen: the seal on this panel that the front of the roof closes down onto came a bit detached, so the dealer fitted a new one, but a 5cm chunk of paint came off when taking the old seal off (hence I’m wary of fixing one small thing, creating a bigger problem!)
For (1) the corrosion on the elevating roof – I assume this would just get stripped back to bare metal in the small affected area and that part resprayed, without e.g. the canvas being removed, hence lower risk of creating bigger problems?
For (2) corrosion in the front roof drain area: this is under the hydraulic pipes, so a repair would presumably involve removing the front panel, with resulting risk of leaks/damage to hydraulics etc?
For (3) and (4): could the body shop just respray the front panel without removing it?
I’ve read on this thread about cutting away parts of the front panel and fitting a plastic cover, which sounds worse than living with the corrosion, so I’m keen for input from people who have had similar work done.
I’m also keen to know which of the available warranty body shops are recommended (or best to avoid): I started a separate post on this here:
https://vwcaliforniaclub.com/thread...-shops-for-warranty-repair.54665/#post-709653
Thanks for your help!
