Roof not opening or closing
DOMINICGG1234
DOMINICGG1234
Chichester
T5 SE 140
Hi all
Stuck in Belgium and this has happened. Any advice gratefully received. Thanks
If you can get to the emergency release of the hydraulic pump, you might be able to slightly open the screw, and try to even out the roof by pulling or pushing one side. Then close the screw again and try again.
If not, lower the roof completely (with the emergency release), and after closing the screw again, try again.
What model do you have? Whereabouts are you located?
The screw looks like this (red arrow):
In place it looks like this (screw sticks out on the underside):
And is located behind the central display, packed in yellow foam:
If you can get the central light out, and maybe push out the control panel, just cut open the foam, and try to locate the screw.
You have tried the turning the control panel off and then back on again method first?
Then try with engine running.
Thanks for the replies. Triplebee I got someone out and they followed your instructions. Very useful thank you. Tie down kit now installed. Guess I’ll have to limp home at slow speeds as not sure how much I trust those straps
All appears sorted now but by releasing that screw would that cause the hydraulic fluid to escape as I have some kind of fluid escaping from the front right of the van now
No, it just drains back into the pump reservoir.
The fluid escape, same side as the roof drop?
Probably a hydraulic fluid leak from pipe/pipe join or hydraulic ram on that side.
The reservoir apparently is empty. Yes it is the same side. Dripping underneath the van
Yes it is the same side. So guess I don’t need to worry?
99.9% sure you don’t need to worry.
However, I’m not sure how the roof can be opened with no hydraulic fluid in the pump. Possibly by opening the bleed screw , a little NOT removed, then the roof can be pushed up to sort the actual leak.
Is it me or does that bungee look a bit too aggressive. I'd be concerned it will pull the bellows out of the corner securing channels.
Thanks for the advice. Straps attached and just arrived home after limping ba k from Belgium at 50mph
