V
vbk1975
To extend this slightly, i think this is the likely sequenceI would never presume that to work. If I was programming the system, it would be like:
1. Car is turned off
2. Is roof up? Yes - start timer. No, do nothing.
Autocorrect
1.Use Button to open roof, Roof Opens, Both Open Sensors Detected, Release Button (Or Hold) and Pump keeps going until roof pressurised. (Electrical Current exceeds the number of Amps that is required to drive against the check valves)
2. Ign Off (Timer starts)
3. After X mins roof is checked.
- If Roof Sensors are showing fully open - do nothing
- If Roof Sensors are not recording fully open - drive pump until sensors recorded and roof pressurised.
Keep repeating 3. every X mins (First check and subsequent check times could be different)
If Ign is switched on, then cycle starts again at 2(ie timer reset) when Ign is switch off.
if Roof Lowered by User (Button) then No Auto Correct
