Shelves in the wardrobe
crookrise
Skipton
T6.1 Ocean 204
Just a post to show an idea for adding shelves, I used laminate flooring to match the interior of the van.
Just one piece from Homebase as a sample !!
Shelves are held up by square profile wood beading stuck to the wall with double sided tape, easy to remove and no drilling.
Nice job. There has been problems with previous attempts (glue coming unstuck in hot weather), but your approach using the vertical 'sticks' should have a better chance. I think the previous tries used horizontal 'suspended' supports. I may have a go myself!
Nice work! I like the look: clean and simple
Why not just drill holes and use the same shelf clips used on the California?
No danger of the sticky tape coming unstuck in the heat.
Not that good at getting 4 holes for each shelf in exactly the right position !!! Mind all the attempts would help with keeping the cupboard cool.
A simple template would work.
Here's a solution if you feel like spending some cash...
JuanVecino2023
JuanVecino2023
JuanVecino2023
JohnCalifornia
kenseaton
kenseaton
YorkshireWander14
YorkshireWander14
YorkshireWander14
JohnCalifornia
JohnCalifornia
JohnCalifornia
