Side Blind Issue
JPCL
JPCL
Lancashire
Hello everyone , I'm having problems with the side blind on my T6 ocean (the one by the sliding door) I can pull it down but can't get it to retract up. Is there any quick fix? it's a 2016 reg DSG califonia ocean. We recently had anew seals installed for the side door & driver side door.
Make sure the trims that are around the blind are not out of position. The blind runs in a rail that is not directly visible and sits behind the trim. If the trim is out of position it can rub against the blind. The trim should sit such that the rail is central to the gap.
Have a read and help understand how the blind works & sone of the potential issues
Many thanks for the reference items. I seem to be missing one of the black guide ends, but the silicone lube seems to have solved the problem as the blind now retracts fine. Many thanks all
Check the end plug is not in the bottom of the channel (as in my post ), you do need to look closely
Bjohnson
llackford
Quinnster77
Quinnster77
V
vw California
V
JohnnyAppleseed
