Hi Gazellio, how did you get on with that wheel, tyre and chain combination? I'm looking to upgrade to 18"s - the manual says you can't go that big/wide and use chains, but I thought it should be possible, hence intrigued to see you've done the same! Cheers,My advice would be "Winter Tyres" with a set of Chains just in case but you will probably not need them. Snow socks work but get worn out very quickly whereas chains can be used for many years.
