if you can charge at home and will only be using pitches with EHU, then no need.Like the idea of solar power but struggling to justify the outlay and is it actually needed what’s peoples views ??
We have just a single panel and it does the job and does extend battery life significantly if you are Not heavy users. You can just get a single panel and add another later if required. Roger from Solarcampersolutions can supply an additional panel and connection if required.Thanks for your answers I am able to regularly charge at home However we stay at plenty of places without EHU but don't seem to have a problem Will solar extend the battery life ?? Been looking at solar camper solutions shows a single unit or a double Is a single enough ?? Thanks
Search Amazon for a 12v charger for your particular laptop. Don't go for the cheapest.Good morning went ahead and have fitted a kit from Roger at solar camper solutions excellent service and any questions I had answered straight away highly recommend My question now is what do I need to get to charge a laptop from the 12 v sockets or is there anything I can get that uses the 2 pin inverter socket at the back of the passenger seat any links on Amazon etc would be much appreciated Thanks
You could use your existing charger with a plug adapter on the Inverter socket provided your charger is less than 300w power consumption.
The T6. 1 has a 300w inverter apparantly. Other models are 150w.300 W. ?
The inverter converts 12v to 240v. You can plug your laptop mains charging cable into it.Thanks I’ll have a look I’m a little green concerning Electrics what exactly is the inverter socket how does that differ to the 12v sockets?
The Inverter socket converts 12v to 240v mains.Thanks I’ll have a look I’m a little green concerning Electrics what exactly is the inverter socket how does that differ to the 12v sockets?
Paulo12. Icon says a T6
Can't see that on my phone.Paulo12. Icon says a T6
