Gigio1000
- Messages
- 13
- Vehicle
- T5 SE 140
Good evening at all, I have a 2010 California vw that still put the original Varta agam batteries from 75A
Since I no longer had the power of the webasto and the fridge, I decided to change them with two Exide from 80A
In the fitting I also found the 50A fuse on the battery back burner positively and I replaced it with the same.
After completing the installation and verifying all the other fuses, the display shows battery values that indicate 13.1 V battery 100% and 0.0 A.
After a few seconds from power up, the values go to 13.9 V and> -23.0 A with the G flashing icon and the word "Battery Over!" Even though I did not turn on anything.
Do you know how to solve the problem? To someone happened? Do I have to reset the display unit that has been reset by unplugging the batteries?
Thank you for your kind help.
Greetings
Greetings
