IanE
Just wondered if others had this small but annoying problem and hopefully hit on a solution - the left hand door slides with ease, but the one under the sink has always required a shove to slide it open. We've put up with it until now, but it's beginning to bug me. I've applied lithium WD40 to the runner to no avail. I've managed to get a photo of the sliding mechanism which I insert here. There are two of the parts that are attached to the door itself. It looks like the parts attached to the door are fixed with Allen key style screws - could it be that if these screws are loosened, the sliding action would be eased? They are v tricky to get at and I'm a bit nervous about having the door come loose and getting it back on would be quite tricky. You will have guessed by my poor command of the correct terminology that I'm no DIY expert!
Any advice gratefully received
Ian
Ian
