Flower Power
I am thinking about installing a stronger replacement for OEM engine/gearbox protection shield. Instead of "plastic" I could use: (from eBay.de)
1. Aluminium, 3,5 mm, 9kg 299 euros
2. Steel ,2 mm, 12,57 kg 169 euros
One of the dangers I envision living in the Alps is/are ice balls left after plow goes and leaves a mess. Sometimes they will freeze solid overnight and are 30 cm high and are like rocks. Which plate would make a better sense? Steel will rust fast in the salt. Alu will resist. What do you think? Anyone has it? Which brand? Thanks.
