sapto
Don't want to make it worst but i don't call that a scratch anymore...looks like pretty well damadged...
Some kind of curbstone in a parkinglot ....?
Thanks for sharing, scary stuff, I dread the day I get my first scratch. This will keep me sharp and focused on not doing so. Hope they fix it quickly and as cheap as possible for you.
Hi Alan,It felt much worse than it was. The bar is just shy of touching the sill.
Once I had stopped safely to take a look, I was mightily relieved, although still p****d off that I had done it.
Misjudging the length of a van is not unusual. I similarly bashed the T4 and T5 work vans I had, so you would think I would have learned my lesson by now!
AlanView attachment 9629
Hi Alan,Hi Borris,
An interesting suggestion and one I had not considered. I do have a friendly garage who may well allow me to do this on their lift.
My only thought is that these sill bars are mounted at each end onto a bracket that is bolted to the sill via two cleverly designed bolts through existing blanked holes in the sill.
Given the thickness of the metal of the vans body, if I were to try and bend the bars back in situe I suspect the sill would give way and the bolts would pull through before very much bending happened.
I could use wooden blocks to support each end and this would prevent the brackets pulling out of the sill.
There is still and gouge in each though, where I hit the rocks, so these would still be there even if the bars were substantially straight.
I am not panicking about sorting the sill bars out just yet. We have a Spanish holiday to come and so I will wait until after that to deal with them.
Alan
Sorry to hear about your sill damage Sapto. I drive a long wheel based van at work and it is not unusual to see a dink in the sill of one of the fleet where someone had taken a corner a bit tight and scraped a high kerb.
Has anyone heard anything about this make? http://www.direct4x4.co.uk/volkwage...gle_shopping&gclid=CI29qrSx4McCFQQUwwodyq0KLA The firm are based in Derby.
They are black powder coated but as my Cali is black they would blend in quite well and not look too conspicuous. Bit concerned about the lowering of ground clearance and someone's post where they said that the jacking points could not be used.
