18months have passed but I wondered if anyone else has this setup using the Thule Backspace XT cargo box (on the tow bar rack) with a VW tailgate rack also used?I'm currently looking in to this option too. I've had a long chat with Thule and it seems the tailgate will open with carrier using the velospace XT3 carrier as this has an option to extend the angle from 50 degrees to 70 degrees. The question now is whether the box will fit under the factory fitted bike carrier (my aim is to use both). Apparently there needs to be at leat 802mm of clearance from the centre of the bumper (around where the sensors are) and the underside of the bike carrier. My van (T6) is in for repairs and so I'm now waiting to measure! Let me know if you've got any further. It seems like a great option for extra storage!
I have the t5 style bike rack for my t6.1 that’s on order And also have the Thule velospace xt3 and backspace box, I saw some posts on a German forum showing that it fits under the rack fine18months have passed but I wondered if anyone else has this setup using the Thule Backspace XT cargo box (on the tow bar rack) with a VW tailgate rack also used?
Andrew mentioned needing 802mm of clearance from the bumper to the underside of the bike rack for the cargo box to fit - would anyone with a VW rack have a moment and be kind enough to measure, please? I dont have a VW bike rack yet but I’m leaning towards a cargo solution on the tow bar mount and bikes on the tailgate (cant use a roof box as will be carrying boards)
Hi all,
I have this fitted as we speak. It does fit with a Quasimodo T6 bike rack, but you need to tilt the rack forward-back to fold the tailgate rack down.
Images attached.
Tailgate opens fine with the rack in place. Needs adjusting to the max tilt though.
Thanks for sharing these images, really useful as I am contemplating this set up.
Absolutely a very valid point.@SusiBus , now carrying 30L water with the above setup could be problematic as Axle weight will be increased by Weight Carried X Distance from Axle.
Hello I have a similar setup but I am struggling to see how to adapt the tilt of the box. Can you advise please? At present the boot will not open as the box is in the way.Hi all,
Images attached.
There’s a metal wire and it has two slots that you can connect it to, you just need to move it to the lower settingHello I have a similar setup but I am struggling to see how to adapt the tilt of the box. Can you advise please? At present the boot will not open as the box is in the way.
