Turning rear climate off
JohnCalifornia
JohnCalifornia
North Yorkshire
T6 Ocean 199
Hi , any ideas how to turn the rear climate control unit off ? I have seen it saying off on it but now can’t seem to turn it off at all. I’ve read the manual but doesn’t give me much info. I’ve only just found out what the rear button does on the dash, not by reading the manual but on previous posts on here. Thanks for any replies
Just watched the vid, it’s a T6.1 on the vid and mines a T6 but look similar. Doesn’t really say how to turn the rear off just that it can be. I’ll have mess around this afternoon
I was being a little lazy before! Just checked ours (t6.1 coast) and there is an off button. Obviously not sure if this is the same with the t6.
I’ve done it. Keep pressing the minus fan speed button on the rear control panel and it turns off. I’ve never used it before so when I got my Cali back from an AC repair and it was on full blast due to them testing the system probably and I didn’t have a clue how to turn it off . I do now. Thanks for the replies
Or press 'rear' on the centre console, it then shows you what settings are in use in the rear, which means if you then turn the fan speed down on the centre console (whilst 'rear' is illuminated) you are in fact turning the rear fan down. Lowest setting is off.
Again this forum helps me out!
I was getting confused with the rear button meaning the tailgate windscreen heater -doh! (which btw there isn't one)
So now I know how to turn off the rear blower
