Mervyn kennedy
- Messages
- 76
Hi all
Not sure how many people have a storage drawer wher the slide through panel is under bench seat .while every one looks for more space and this is a huge amount of space in ours anyway wasted and not accessable for anything .
So I fabricated a long box 600 mm long 170 mm wide and I think 200 high out of aluminium .welded in ends on each side .
Ours has the compressor tucked away at the booth end so that had to come out and the oval head bolt and rivers that the gray panel hinges down on .one screws out other two had to wring them off.
I do think you can order a pocket here info you have a spare sheen but we don't and the compressor is stationed here so couldn't get it .
I fitted two soft closed rails to side of bench seat and drilled and tapped side of new box .
That in place next was to fit panel to front of drawer which wasent as easy as I thought as this sits at an angle .
Used two stainless steel pieces and glued them to rear of panel after taking off the plastic bracket that hols it in place .
Then using m5 stain steel bolts long for adjustment tapped and screwed to stainlesssteel panel top and bottom .ddilled in to drawer screwing out front panel to get it just right then cutting and using dome head ss nuts inside drawer . Put a draw cord out through front of drawer to open it and this is what it looks like .sure some one is going to show one Done in Germany or somewhere but this is the first I have seen . We use it for fruit and some treats and food .breakfast items etc .
Anyway have a look .
