dfps
Hi,
My main engine battery has been running down so before replacing the battery I ran VCDS and it reported " rear right speaker open circuit "
So my questions are :
1. Will an open circuit cause the battery to run down over a period of several days.
2. I am not sure if there is a speaker located to the side of the rear bench seat/bed on the drivers side opposite the kitchen unit ? There is certainly an open area in the fabric
covering.
The reason I ask this is that the rear overhead locker speaker seems to be operating okay on both right and left.
Could the VCDS be referring to a speaker to the side of the bench. There is no sound coming from behind the grill so I am not sure if there is a speaker there or not.
If there is an open circuit to a speaker in that location the lack of any sound would probably indicate where the problem lies.
3. If there is no speaker in that location, can the overhead locker speakers still work and have an open circuit ?....I thought an open circuit means there is no power getting there.
My Cali is a 2007 SE 2.5 Tip Model
Any help would be appreciated.
covering.
