Big Ted
Our 2008 T5 Cali arrived last Friday and came with a sport line spoiler fitted.
Long story short, we wanted the VW bike rack and not a towbar job.
I trawled this and other forums to see if this was possible, but never really came to a conclusion.
Chance had it that I managed to pick up a VW rack for a good price and so I was duty bound to have a go.
Spoiler was removed and paint work a bit tatty underneath.
Plan A
Cut the underside of the spoiler way and mount over the top of the rack.
Pro’s - would look great.
Cons - would seal bike rack onto van and cause a headache later should I need to remove the rack.
Over the last few evenings I’ve been tweaking and cutting and tweaking some more to see if I could mount it over the rack and the answer is NO.
Plan B.
Now I’ve a spoiler with large chunks taken out of it, I may as well chop it into 3 pieces.
One for each end and the bit in the middle.
The end pieces fit a treat. You can clearly see why the spoiler won’t fit over the rack, as it stand quite proud of the spoiler.
The middle part came next and here is where things are now too tight for me.
As a 6’8” chap I ride the largest bike I could find, with 29er wheels/tyres. Due to the weight of it, I want/need it to be closest to the rear window. With the frames geometry I can only clamp onto the vertical seat tube, which requires this arm to be slid a far way off centre. The net result of this sees the mechanism obstructing the placement of the middle piece of the now butchered spoiler.
I tried it in the central position, but here too all 3 arms are fouling the spoiler.
You can see a good air gap here...maybe a thick layer of sealant could raise it high enough?
I may think about heating it all up and applying some force, but to be honest, I think it’s only going to be me who sees it anyhow.
Next steps.
I’m thinking of filling the ends with expanding foam, then sealing them somehow. Maybe with an off cut from the middle part of the spoiler. Then I’ll bolt and bond these two into place.
Next, I’ll clean up paint work in the middle portion and find a suitable 3M wrap to cover this section.
Pictures to follow with the end result in a few weeks, as I’m away for a bit.
Summary.
Would I spec a replacement California with a spoiler and go through all this again? No.
Would I buy a bike rack and a new spoiler with the view to fit them both? No.
Am I pleased with the result I’ve ended up with? Yes, but I’ll only be happy once the job is finished.
Plan A
Plan B.
Next steps.
Summary.
