VW California owners in cornwall - recommendation please
Melinda Rickett
Truro
T5 SE 180 4Motion
Can any Cali owner in the Cornwall (or Devon) area recommend a business that could help us with a faulty leisure battery issue. Our hook up doesn’t seem to be charging our leisure batteries. The fridge runs for three days and then we need to run the engine to get fridge back in again. Thanks for any recommendations
1. When on Hookup, do you have power to the Mains socket on the end of the kitchen unit?
2. When on Hookup do you have the Plug icon on the Control Panel screen, L lower corner.
If 1 is Yes and 2 No then check the Mains lead to the built in Battery Charger. It looks like a kettle plug, it can vibrate loose. Depending how old your vehicle is the Battery Charger is either below the fridge, accessed via L lower kitchen cupboard, or above rear Leisure battery, accessed via opening via the boot, L lower wardrobe.
If 1 is No and 2 is No then check the lead connected to EHU and that the circuit breaker in rear wardrobe is On.
If 1 is Yes and 2 No then check the Mains lead to the built in Battery Charger. It looks like a kettle plug.I
Thanks Welsh Gas - we don’t have the icon on control panel so think we need some professional advice on this when we return to Uk
Do you have Mains supply to Kitchen socket when on Hookup?
Kernow Transporters know their way around a Cali and have a good rep here & on the T6 forum (Penzance area)
Thank you for that recommendation - we’re just back from our travels to will now look into further
