Ps big thanks for replying
Nina Harry, Hi, I have the same problem where i cannot get the Easyfold XT2 to attach to the towbar (i think it might not be possible so feeling a little stupid). So my q is did you manage to attach and if so how, thanks in advance!
I quite often have the same problem with my XT3 Easyfold. The solution is to push the clamping lever back even further. From memory it has to further back than vertical. This will open the clamp far enough to go over the tow ball.
The plastic caps on the XT2 seem to contain a hole through which the bolts pass that allow the tilting. Will removing them compromise the tilting mechanism?
I just wanted to make sure everyone who is considering the Thule Easyfold XT 2 (933) for a T6.1 (with factory supplied tow-bar) knows that;
OUT OF THE BOX - THE TAILGATE CANNOT BE OPENED/CLOSED EVEN WHEN THE RACK IS TILTED
aka - the rack is NOT compatible with T6.1
I will be returning mine and ordering a Altera Genio Pro (fingers crossed this does fit)
The modifications suggested on this forum will allow it to tilt sufficiently, but in my opinion unless the bungs are reinserted, the structural integrity of the steel tubing is compromised. The bung offers dimensional stability to the tubing when in situ.
Hi, I just cut the bungs leaving a couple of mm on the lip and then reinserted them to keep tube integrity (and bolt going through) and allow to fold enough to open the tailgate.
HappyGus
9K
66tim99
66tim99
rupertpoon
Gliderbee California 6.1
G
PengySass
5K
MaldeNswiss94
D
7K
Jim2007
