That's it. If in the central position when engine starts then wing mirrors do not heat. Move switch to another position then back to Heating Position, this turns the heating elements on. Just like a rear window heater.OK , learning new things here ....
Only used it a few times just switching on and off i guess.
WG , can you point out step by step how to?
Apparently a timer, so that they switch off after a set interval.That part i figured out as i used it that way , but you still need to swich them off.
You did mentiont a timer...or am i confusing things.
Tkx anyway.
My dealer said the same on handover told me that you have to switch them off after use or they will damage your mirrors because they stay on. The timer makes things better, so I can just flick them on and off and they will work for a set time? He did not mention that at all.Interesting.
Advice given elsewhere has been not to leave the switch permanently in the centre position because the heaters would then be on all the time that the engine was running.
If there is a timer as described then I wonder what happens if the switch is already in the centre position and you first start engine - does that start the timer?
Time for a test drive to find out
I can't believe they don't turn off, as so many people would forget to do it manually. There would be a warning light.
Right
Off to test
Ah, wellThat was a long drive!![]()
Hello Welsh gas, you seem to be knowledgeable on California so I’ll ask you! My wing mirrors don’t work I think?? It’s a 2007 CaliforniaFound this useful info on the T5 Forum regarding the Heating function of the Wing Mirrors. The poster is very knowledgable.
Hi, I'm don't know Col the gas, sorry.Hello Welsh gas, you seem to be knowledgeable on California so I’ll ask you! My wing mirrors don’t work I think?? It’s a 2007 California
How can I get them to work or turn on?? Also doesn’t seem to be a rear window demister anywhere??
I see you’re in the Vale??
I’m from Llantwit Major
Now in south Pembs
Did you know Col the gas from LM??
As I recall when the double glazed option was taken (2017) I was informed that I'd lose the heated rear window.There isn't a heated rear window, its double glazed instead.
If you have heated mirrors the switch is the same one that you use to move the mirrors, just turn it round.
Always has been on ocean/SE with option to change rear window to single glazed & heated.As I recall when the double glazed option was taken (2017) I was informed that I'd lose the heated rear window.
Double glazed now standard?
Definitely recall conversation about not having heated rear screen when I ordered my Ocean back in 2016. He made quite a point of it, but then he couldn't locate the tow ball when handing over so product knowledge was very questionable.Always has been on ocean/SE with option to change rear window to single glazed & heated.
Thanks, we normally when parked up have them folded, so at least it’s been off then.1st photo is mirrors folded, second is heated mirrors on & is the only position that keeps them on.
So move it to LR or O if you don't want them on.
