Programmable feature with Carista?
Matthew Mills
Matthew Mills
Living the dream...
Somerset
T6.1 Ocean 204
Hi all
I have bought a Carista dongle and App... What can I personalise on my T5.1 Cali then? What's good etc? I know about doors, windows etc., etc. But what's the clever stuff then?
Thanks in advance
Matt
http://www.caristaapp.com/features/
If you follow the instructions on here regarding Customisation it will tell you what you can do on your particular vehicle. Each vehicle can vary depending on what has been programmed into the car computer.
I read that... and those features are cool and I will be changing a few, but I was wondering as it states it's a sample, what else there is I can play with, mirrors on the fob button etc...
Your car, the way you want it
Carista can configure the way your car behaves. Do you want to unlock only the driver’s door with the first click on the remote, or do you want all doors to unlock at once? Do you want to change the language on your dashboard? Do you want to change the way your parking-sensor beep sounds? Yes, Carista can do that, as long as your vehicle is supported. No other app does that. Just try the “CUSTOMIZE” button and Carista will automatically determine what options are available for your specific vehicle. We support hundreds of different customizations for VW, Audi, BMW, Mini, Toyota, Lexus, Scion, Seat and Skoda. We are working hard to expand our support to more settings and more manufacturers
This section.
Lol, yep, read that too when I bought it...
I just can't find a list online (full list that is). I've not yet plugged it in. I'm going to this weekend, I will write a complete list of all the features that can be 'controlled' and add them here for general reference...
Thanks for your help WelshGas
There is not a full list published online, as it differs for each vehicle, depending on the options ordered when the vehicle was built, and the exact age and spec of the vehicle.
You can however get a full list for "your vehicle", and either email it to yourself or upload to cloud storage. It is in a .pdf or text format that you can copy and paste if you want to.
Another helpful chap, thanks Dav1d - logical that it varies, and this Carista app seem to be good, that a good feature...
How much is the InApp Purchase to make the changes?
WelshGas - good question... $20 and it's meant to be a one time purchase, I've yet to connect the OBD dongle so have not really done anything to get that far... As soon as I do I'll do some screen grabs of the app and what it does as well as upload my configurable list... as Dav1d suggested above...
Will be interested in what can be changed here, I have a few OBD interfaces at home I could use.
Auto locking doors are one thing that irritates me by its absence on my cali.
Yep, can have them one click, drivers, 2 all, with out tailgate, auto lock on drive and auto unlock as you remove the key etc.... I will play and post the list.
Matt
Its just for show but I like the option of having the dashboard needles sweep round the dial and return on starting.
Presumably given the price difference between Carista and VCDS there are still things that Carista cant set? eg if you add new functionality such as MFSW buttons / towbar?
Ordered a Carista dongle as a result of seeing this thread. It's just arrived & this is the option report for my cali...
Doors / Windows / Remote
Auto-lock doors when moving
YES / *NO*
Auto-unlock doors when key is taken out of ignition
YES / *NO*
Auto-lock trunk when moving
YES / *NO*
Unlock trunk when doors are unlocked
*YES* / NO
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking with remote
YES / *NO*
Beep when unlocking with remote
YES / *NO*
Beep when alarm is armed
YES / *NO*
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / *ALL DOORS ON 1ST PRESS*
Enable settings for opening/closing windows and sunroof
YES / *NO*
Open/close windows via long-press on remote
*YES* / NO
Open/close sunroof via long-press on remote or key
YES / *NO*
Open sunroof via long-press on remote
YES / *NO*
Close sunroof via long-press on remote
*YES* / NO
Open/close windows by holding key in door lock
*YES* / NO
Blink turn signals when done closing windows via remote
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Enable remote control buttons when ignition is on
YES / *NO*
Instruments / Display / Dings
Instrument cluster language
CHINESE / CZECH / DUTCH / *ENGLISH (UK)* / ENGLISH (US) / FRENCH / GERMAN / ITALIAN / NORWEGIAN / POLISH / PORTUGUESE / RUSSIAN / SPANISH / SWEDISH / TURKISH / NONE / SYMBOLS (NO TEXT)
Instrument cluster region (affects ext. lights too)
GERMANY / EUROPE/OTHER / USA / CANADA / *GREAT BRITAIN* / JAPAN / SAUDI ARABIA / AUSTRALIA
Temperature display units
*CELSIUS* / FARENHEIT
Distance display units
KM / *MILES*
Speed display units
KM/H / *MPH*
Pressure display units
*BAR* / PSI / KPA
Volume display units
LITERS / *GALLONS (UK)* / GALLONS (US)
Time display format
*24H* / 12H AM/PM
Date display format
*DD/MM/YY* / MM/DD/YY / YY/MM/DD
Consumption display units
*MPG (UK)* / MPG (US) / L/100KM / KM/L
Multi-Function Display
*ENABLED* / DISABLED
Seat belt warning
Lane-change turn signal auto-flasher
Lane-change turn signal auto-flasher count
1 FLASH / 2 FLASHES / *3 FLASHES* / 4 FLASHES / 5 FLASHES
Lights
Daytime running lights
ENABLED / *DISABLED*
Allow configuring daytime running lights via dash display
YES / *NO*
Coming-home lights (req. auto headlights or manual flick of high beams)
Leaving-home lights (req. auto headlights)
Coming/leaving-home lights use…
LOW BEAMS / *FOG LIGHTS*
Coming-home lights duration
10 SECONDS / *15 SECONDS* / 20 SECONDS / 25 SECONDS / 30 SECONDS / 35 SECONDS / 40 SECONDS / 45 SECONDS / 50 SECONDS / 55 SECONDS / 60 SECONDS
Leaving-home lights duration
Turn off front fog lights when high beams are on
YES / *NO*
Cornering lights (using fog lights)
Turn on cornering lights when turn signal is on
*YES* / NO
Turn on interior lights when key is taken out of ignition
*YES* / NO
Flash brake lights in emergency stopping
YES / *NO*
Flash hazard lights in emergency stopping
*YES* / NO
Brake lights work even when ignition is off
*YES* / NO
"Euro" parking lights when ignition off, turn signal on
Other
Activate side mirror heaters when rear window defroster is on
YES / *NO*
Automatic wipers (using rain sensor)
Speed-dependent windshield wiper speed
*YES* / NO
Additional 'tear' wipe after windshield washer use
YES / *NO*
Auto-enable rear wiper when front wipers on and reverse gear engaged
*YES* / NO
Horn works even when ignition is off
YES / *NO*
Very Interesting. Thank you for posting.
Now, the $64 question. Have you altered anything and did it work?:thumb
not tried yet, only had a quick look, will try later, however, I suspect i'll need to make an in-app purchase to do that. when I get more time i'll look into other 3rd party apps & see what they have to offer. will let you know.
I'm wondering if this will have the BT option in it. Worth a punt if yes, not much else I'd want to change except maybe doors locking when moving.
Looks good. Do let us know if it works!
There's a few things, I would change straight away:
YES / *NO*
YES / *NO*
YES / *NO*
YES / *NO*
I think the " Configure DRL via Dash Display " could be useful when camping.
Looks like I might have started something here... The dash needle sweep was my favourite! Mine below: -
But there's seems to be little to no difference overall - I'd expected some for the DAB etc...
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
YES / *NO*
*YES* / NO
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
*YES* / NO
*YES* / NO
YES / *NO*
YES / *NO*
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
KM / *MILES*
Speed display units
KM/H / *MPH*
*BAR* / PSI / KPA
Time display format
*24H* / 12H AM/PM
Date display format
Gauge needle sweep at startup
*YES* / NO / NOT AVAILABLE
Seat belt warning
Lights
YES / *NO*
*LOW BEAMS* / FOG LIGHTS
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
*YES* / NO
Other
YES / *NO*
*YES* / NO
YES / *NO*
*YES* / NO
YES / *NO*
Does ** mean the current setting? Assuming so, it's interesting that you both have different DRL settings, unless you have changed yours surfer-rich?
Another Android app that's really good for stuff like this is Torque (Lite or Pro). I don't have a Cali yet but on my Subaru it's great for reading and clearing fault codes as well as just monitoring stuff for the sake of it :)
I have Xenon lights so maybe it's different to DRLs that mount in the bumper below the headlight... I don't know...
If it turns off the PITA automatic wipers Id buy one immediately.
According to the dealer this is a health and safety issue and cant be done.
I've got auto wipers on my transporter and love them - I really miss them when I'm in the cali. No more fiddling endlessly with the intermittent delay when you get that funny drizzle-not-quite-rain
Sent from my Galaxy S6
