Does it invalidate the warranty then?
Well, someone had to ask.
I'm sure those transporter engineers will be thrilled messing around thrying to reset it! Probably make holes in the floor and cover it in oil for the priviledge too.
Of course, they won't be able to work put what's wrong with it![]()
If it turns off the PITA automatic wipers Id buy one immediately.
According to the dealer this is a health and safety issue and cant be done.
I would have changed some by now. It arrived today, but when plugged in, although it lit up red, no wifi or Bluetooth signal. So I've just packed up to send back for a replacement.
Yes, ignition on, multiple times. No WiFi signal detected, on 2 iPads and a laptop. No Bluetooth signal, checked with 2Android phones. Not the end of the world. In the post tomorrow and have ordered a new one.Did you turn on the ignition WelshGas, I also parked close enough to the house to have phone on wifi... I believe you need to link via the network... But then I could be wrong (Mrs M says I'm wrong lots of the time - but she's wrong...)
Matt
Each to their own I love them... I love them but yes you can urn them off: -
Automatic wipers (using rain sensor)
*ENABLED* / DISABLED
Above is my setting...
You can also enable/disable the following: -
Speed-dependent windshield wiper speed
*YES* / NO
Additional 'tear' wipe after windshield washer use
YES / *NO*
Auto-enable rear wiper when front wipers on and reverse gear engaged
*YES* / NO
Hope this helps...
Matt
i think mine is registering incorrect as my daytime lights are on.Does ** mean the current setting? Assuming so, it's interesting that you both have different DRL settings, unless you have changed yours surfer-rich?
I had to buy the 'in app purchase' at £14.99 to make changes but, yes, it does workVery Interesting. Thank you for posting.
Now, the $64 question. Have you altered anything and did it work?![]()
Thinking about this... I have Xenon lights, so is this different to DRL - yes they are DRLs but I was told that because I had Xenons I could not ALSO have the separate DRLs... Anyone know?i think mine is registering incorrect as my daytime lights are on.
What do you mean by DRL. Do you have any LEDs coming on with the ignition?.Thinking about this... I have Xenon lights, so is this different to DRL - yes they are DRLs but I was told that because I had Xenons I could not ALSO have the separate DRLs... Anyone know?
Okay so here goes:-What do you mean by DRL. Do you have any LESs coming on with the ignition?.
I do not have Xenia and my DRLs are the Main beams that have a dual filament bulb 55/21w I believe. I think the 2015 had LED DRLs in the bumper.
I dare say you can, but would have to be 3rd party and have a controller to dim with indicators and switch off with headlights or parking lights, or whatever the regulations are for DRLs. Also it would seem that some aftermarket units can interfere with radio reception.Okay so here goes:-
I have Xeon - which have a set of LEDs around the edge of the lens... They come on with ignition as DRLs, and I can configure them to be on/off via Carista as DRLs. There is also an option to have a single strips of LEDs that fit in the bumper... And now it seems you have them on a non Xeon headlight - but I assume that is the same as mine or essential a side light?
I was told I could not have both the Xeon and the bumper DRLs in combination... I'd really like to have both! Anyone know if i can?
Nothing wrong with WelshGas.WelshGas exactly... An option I don't fancy...
New Clarista connector arrived today. Connected to iPad Air via Bluetooth.
Fault Code check revealed a code on the Air Con Climatronic module
Heater & air conditioning
Part #: 7E5907040AC
Component: ClimatronicT5
Coding: 0004000103 (hex)
Fault codes:
9473650 Manufacturer-specific code
9474930 Manufacturer-specific code
Agree. Everything is working as it should and strange that both vehicles have Climatronic AirCon.From the 2013 thread the fault codes seem to refer to the extra a/c fan unit in the offside rear.
Flap could be part 3 on this diagram?
https://www.partsbase.org/vw/campmo...-air-conditioning-for-passenger-compartement/
