Negative only makes a single cup.
Actually we do make two cups at a time from our Aeropress, because Mrs VD likes hers pretty weak (her coffee I mean... she likes her men strong, obv. Ahem.).
Seriously though, if you like Americanos or just smallish cups, you'll may well find the Aeropress good for two.
BTW at home I use the Aeropress with an electric kettle that can be switched to 80 degrees, and in the van we try to heat the water to a bit below boiling. It does seem to make a difference to the flavour.
Wow! Steampunk coffee maker - love it!This is my solution to frothed milk in the field, slightly large but effective.![]()
It's kind of a cross between a mokka pot and steamer.
The coffee is the strongest coffee hit I ever had, like Klatchian coffee. Some foamed.milk helps tone it down.
'Flat white' coffee seems to have originated in NZ, with a few cafes in the UK that had kiwi staff adding it to the coffee menu. No frothy coffee for me. Just heated milk, flat. Ha ha. Did someone say "coffee snobs"...I know I shall get into trouble here but I just can't help myself!
Why do people want frothy milk for a latte? Coffee with froth on top is cappuccino - coffee shops have now invented a name for what should be a latte, they call it a 'flat white'. Very odd.
Hope I'm not 'polluting' this thread - the above is coffee related after all............
Interesting reading, I too may have to get an aeropress and join the clan.
Well I've only gone and done it ! Aeropress bought from the York Coffee Emporium with 1 x 200g free and 5 others as a testers. Not sure if its the coffee or the press but this is the best coffee I've ever had.
As promised in a post above a got myself a Aeropress .
Had it a while now , only used it at home so far .
Must say happy with it! But has any of you ever used it upside-down?
Me to, but I do prefer the paper filters and water at about 90, not boiling.I only ever use it that way, never let it drip
...message ends...
