davetherave
- Messages
- 58
- Vehicle
- T6 Ocean 204
Any advice how to remove the fifth seat on a ocean please
Slide seat as far back as possible. Get a flat head screwdriver and pop up the ends of the rails. Remove them and then take the longer silver covers off too. Then you should be able to slide the seat forward to the gaps where you can lift the seat out.Any advice how to remove the fifth seat on a ocean please
now in garage
Well mine didThe question is - will it ever come out again?
Seat removed thanks for the advice just make sure you move bench seat and 5 th seat as far back as you can remove aluminium rail covers and plastic ends move seat to gaps in rails and lift ,very heavy seat out recommend 2 people to do this now in garage
Dealer needs to read the manual!Jusyt reigniting this thread.
I removed the plastic end caps and the aluminium strips as read on here, but struggled to then get the alu pieces back in. Coincidentally it was going to the dealer and they commented on why I'd pulled the aluminium strips out & that it was possible to just remove the plastic caps... Is it ?
I havent found the time or inclination to try again! But wonder whether if the driver seat was all the way forward, whether this was possible?
