D
Daren_Chambers
Where are you buying your greens?Have you tried roasting your own beans? I have been using popcorn makers for home roasting ... Great fun and fills the house with a lovely aroma. The taste is not bad either,
The gear i collected sofar..
My small electric grinder
Result
The show demonstrated that if you have the coffee then straight away have a nap, you can still fall asleep before the caffeine effects your brain, have a 15-20 minute nap and you will wake up far more alert and sharper than if you just had the coffee or just had the nap. You could have the coffee after you wake but that also takes time to kick in. Who knew?
I reviewed the minipresso once, it is good espresso but a lot of hassle and faffing about. Not sure how the other devices compare. http://campervancookout.com/minipresso-portable-espresso-coffee-maker/
haha you are like me, I have a cupboard that is now full of nothing but coffee things, grinders, minipresso, mokka pots, my bizarre 1970s stovetop coffee engine, with pressure steamer, and now an Oomph which is the most used in my van because it so easy to use.
FNM = Feldnespressomaschine
What a dude!![]()
Nice disign indeed , but he will not be making coffee using that off-grid without 220v i think.
And takes up a bit to much space also imo.
God my dad used to drink that, he got used to it during the war. Even the Germans only had to drink boiled up acorns by 1945, things never got that bad for them.
I think you got the inverted commas in the wrong place, it should be Camp "Coffee".![]()
