Fuse for washer jets
DGM
DGM
East Renfrewshire
T5 SE 180
Hi, have looked through the pdfs but can't spot the location of the fuse for the windscreen washer pump, any help appreciated.
I have a 2011 model.
It's the 7.5 amp fuse in the fuse box under the bonnet
if I recall right it is 7.5 brown one under the bonnet -- small fuse box by battery under the devider
Kev pressed send 1st
Glad you sorted I blew my fuse just before Christmas with frozen water in the jets
I had the same issue and have changed the blown 7.5 amp fuse...... next fuse blew immediately and nothing else happened. has anyone had the same issue, is it the pump at fault or is there a switch in the windscreen wiper control arm? still getting absolutely nothing, no noise, no water but wipers moving.
Did you solve this?
I just had the same, replacement fuse blew straight away, so wondering what to do next…?
Thanks for any advice
Did you solve this?
2 possibilities.
1. Electric pump failed/short circuit.
2. Short circuit in the wiring loom to pump
If you unplug the electric pump and replace the fuse and it blows again then need to check the wiring for any chaffing points etc.
If the fuse doesn't blow then highly likely the pump has failed.
Did you solve this?
Hi, it was the pump that had failed and needed replacing.
6K
Steve Barrand
6K
BillBicker
Frankyworthy
Frankyworthy
Frankyworthy
