Looks nice I do the the sportline wheels on a Cali. It sits quite nice standard but will be better with the I take the VW 30mm lowering springs!
Quite a transformation!
Have you worked out if there has been much of a change to the gearing, using a site like this: https://tiresize.com/comparison/
If your old alloys were wearing 205/60s it gives a +3% increase in circumference and therefore gearing.
Very nice transformation! Are those 7" or 8" wide wheels?
I was expecting more of drop at the rear I must admit.
While the lack of weight in the back and the slope of the driveway may be accentuating the nose down look I’m happy to have reduced the excessive arch gap at the front.
As far as the front to rear height difference goes my main concern is the roof height, if I measure it (on a flat surface) and find the rear is higher I’ll look at ways to solve this. Rear springs are a doddle to swap if needed but I suspect these VW lowering springs may sag noticeably once we load the van up a bit more.
Have you told your insurance company about these mods?
