W
Wiza
I’m trying to establish how to read the leisurely battery display! It’s says 20%? Does this mean this is all that’s left? It’s only been used overnigh
Yes. Assuming you have a California with the same display as me!I’m trying to establish how to read the leisurely battery display! It’s says 20%? Does this mean this is all that’s left? It’s only been used overnigh
yes, but this is a better representation.
Also you don't say what of how old your vehicle is in your profiles it says looking to buy?
This is a pic! It’s a T6 Ocean 2017 204 Auto! Not sure what it was to start but it’s only had fridge on overnight!!
It was driven yesterday and has been on hook up for past 5 days!20% overnight could be a number of things but that's certainly very fast. The manual recommends 24 hours on hookup once a month to keep them live.
Assuming you have an SE, Coast or Ocean that suggests either your batteries are at the end of their life; and/or the fuse between the rear and front batteries has blown.
There are some other potentials but the above two are the most common.
If the fuse had gone would it be working at all?It was driven yesterday and has been on hook up for past 5 days!
I think you were right! I started the engine and the % went up straight away! Now on 70%! Thanks all for your help!12.4 is actually 80% not 20% so it maybe that the calibration has been lost on the battery monitor. I would reset the control panel an put it on hookup for a couple of days so that it gets back up to 100%
Did you Reset the Control Panel?I think you were right! I started the engine and the % went up straight away! Now on 70%! Thanks all for your help!
No not sure what to do there! I just turned the engine on and it adjusted itself straight away??Did you Reset the Control Panel?
Have you ever switched the Control Panel OFF, using the L lower button?No not sure what to do there! I just turned the engine on and it adjusted itself straight away??
Why and when should we do that ?Have you ever switched the Control Panel OFF, using the L lower button?
Following up on the earlier ? Can u tell me about how to reset the Control panel & how often should I do it? For example: My dirty water waste tank shows on the control panel it is full even when empty. Thanks. Jennie
Euh, I always switch it off when I end my camping trips. If I don't need the fridge, heater, roof anymore, the display is always off in my California. It uses battery for no reason.Why and when should we do that ?
It’s a Computer. What do you do with a computer when it plays up?Why and when should we do that ?
Tap it with a hammerIt’s a Computer. What do you do with a computer when it plays up?
