Jack missing
CaliforniaBen
CaliforniaBen
Just noticed our jack is missing from our tool kit, what size do I need to get to replace it , with 2 ton be OK?
Probably not missing as may come with tyre inflators & a bottle of sealant. Two ton capacity Jack should suffice.
Do you have a spare wheel or just a tyre sealing kit?
If you have a wheel, you should have the jack, if you have the tyre sealing kit, you won't have one.
@TripleBee incorrect: Ours has a kit and jack (no spare originality). You get a jack because you need to lift and rotate the deflated wheel after you’ve injected the sealant during the inflation process.
@CaliforniaBen I think only the original type of jack will fit correctly into the moulded polystyrene tool holder.
Thanks for clearing that up.
Californication69
AlisonF
AlisonF
Dizzy
Viktorgeorge
Viktorgeorge
15K
jts46
jts46
briwy
11K
jts46
jts46
