On the step or in front of the bed behind the front seats?Hi there,
Any suggestions for best floor mat in back of T5 camper beside slide door?
Brandrup https://www.brandrup.de/en/brandrup.../vw-vehicle-interior/velour-carpets-vw-t5-t6/ if you have three rails but have no intention of using the middle rail(fifth seat) then get the two rail carpet it fits over and the bed still slides. the way it Velcro's onto a plastic strip which slides under the steptrim is also trick IMHO.
Rugs for Bugs, https://www.rugsforbugs.co.uk/
Thanks so much guys for all replies. Great stuff on here.
Give them a call and ask, I'm sure they would love to talk to a potential customer.What are the mats made of. See one which could do the trick but oddly I can’t find details of the material on the website??
My Marvel Mat’s rubber backing has started to disintegrate shedding loads of rubber dust!Carpet tiles between the rails then Marvel washable mat from Dunelm on top is what I have. Just throw the mat in the washing machine when I get home.
How old is it. MInes about 2 and seems ok so far.My Marvel Mat’s rubber backing has started to disintegrate shedding loads of rubber dust!
Also a couple of years. I suspect that it’s where it rubs on the rails so I guess it’s down to me rather than the mat.How old is it. MInes about 2 and seems ok so far.
Guess depends what sort of camping you do. I think you can’t beat rubber matting sheet (coin matting, eBay) from eBay cut to size. The smell disappears quickly. But we get a bit dusty/muddy etc. Fitted to size makes it much easier to sweep out but a bit harder to use the lower bed; you have to roll it up and stash it somewhere.
I bought some carpet from Carpet right, it's about 3mm thick so the bed can run over it when laid. I cut lines for the tracThanks Sandyvan. I have a conversion so my RIB bed has a static base.
I've come to the conclusion that Marvel changed the rubber backing couple of years ago! I have 2 mats one older than 2 years the other less. The older one has a harder backing and shows no wear, the newer one has a softer rubber and shows a lot of wear.How old is it. MInes about 2 and seems ok so far.
