Hi Subthree,I have just bought a solar kit from Roger with the Victron charger. I am interested to know where, and how, people have mounted the Victron unit. Any photos would be really appreciated. Thank you folks.
Thanks Perfectos.Hi Subthree,
there is a thread with some photos, I’ll try and find it and post here
I think generally it’s on the B pillar passenger side assuming it’s the digital display your talking about ?
if it’s the control unit anywhere accessible but hidden
Posted a link in my original post, double sided automotive foam tape would do the job of mounting without drilling - widely available on line (choose a 3m product)Thanks Perfectos.
The Victron unit is tiny - 100mm x 113mm x 40mm. It has built in Bluetooth so no display. I am assuming it will be mounted in the rear cupboard but keen to understand where people have put it and whether anyone has used adhesive velcro rather than drilling.
The instructions provided with the kit give good locations for both Ocean & Beach. I can’t pass you a copy as no longer have them. (For our Beach fitted nicely in the Jack compartment; secured with 1 screw to internal panel using an existing hole, but Velcro would also work)I have just bought a solar kit from Roger with the Victron charger. I am interested to know where, and how, people have mounted the Victron unit. Any photos would be really appreciated. Thank you folks.
I put mine in the top of the rear cupboard. You run the cables up the left hand side of that cupboard from the leisure battery and the input from the solar comes in at the top, so top of cupboard works well.Thanks Perfectos.
That what I was thinking as well, top of the cupboard, as when we go biking I can fit 2 helmets on the top shelf.I put mine in the top of the rear cupboard. You run the cables up the left hand side of that cupboard from the leisure battery and the input from the solar comes in at the top, so top of cupboard works well.
Really appreciate the photos, thank you.
Much appreciatedHere's where I mounted my Victron MPPT ...
WARNING the inside of the Cali and this aluminium panel can get VERY hot in sunny 30C+ temperatures so I mounted my MPPT on small standoffs to reduce the heat transferred to it and all works fine
