Help identifying parts for a 2014 T5.1 SE
Tactical
Tactical
Devon
T7 California Ocean 4 Motion
I have been informed that the following parts need to be changed on my 2014 T5 SE.
EPIS 733 California Camper 2014
Ill-No.PosPart NumberDescription
875-010(10)7E7875059K UV8Bellows Grey
915-00015000915105CDBattery, filled and charged
915-00025000915105CDBattery, filled and charged
875-00056X0877236ADrain tube
875-000137H0877221AWater drainage hose
875-000127H7875537CConnecting piece
875-000217H7875211ADrain tube
875-00047H7067800CDrain hose
Can anyone point me to the vehicle spares diagrams that show each of these parts please?
I am concerned that the bellows may be for a T6. Do these fit the T5 as well?
How can I tell whether the bellows specified does have the front opening window (in addition to the side ones)?
Can anyone confirm please whether the batteries specified are suitable replacements for the T5 AGM leisure batteries? My search of the part number suggests that these may be lead acid starter batteries.
Thank you
I believe the t6 bellows are a different material to t5. Not sure on fitting but I seem to recall roof toppers rainbow screens etc use different measurements betwixt t6 and t5. The front opening is an optional extra on some models like beach so i would ask to pay this if you wanted it or you may get standard bellows.
Also, what do you mean you have 'been informed' this work needs doing? By who?
Thanks ArunAlec.
I tried navigating that site already but it's hard to find the right diagram(s) containing the parts and the Part No. search is not helpful either.
Fair question. I cannot say at the moment. I may post about it when the issues are resolved.
Thanks ArunAlec.
If I recall you need to look at the
Campmob.​
Pages
Try looking at this site. Some of the parts are showing up apart from the bellows.
I can confirm the T6 bellows fit the T5.
I own a T5 2011 and while I had the roof corrosion problems fixed, VW replaced the bellows (they need to take these out to do the repairs and they aren't always able to put the original bellows back).
The T6 bellows are made of different materials then the T5 ones. Much sturdier and more waterproof. They do seem to let more light through. Which I find to be an advantage, but not everyone agrees.
Also, I love teh fact that my T6 bellows have a front window. I'd opt for that for sure.
Thank you
Lead Acid batteries indeed, 2014 Cali's were delivered with that type battery
Bellows for VW T5 / T6 California with large front zipper opening (VW part number)
Manual roof:
Dark grey: 7E8 875 059 C IU7
Light grey: 7E8 875 059 C UV8
Blue: 7E8 875 059 C UR7
Red: 7E8 875 059 C UW9
Electrohydraulic roof:
Dark grey: 7E7 875 059 K IU7
Light grey: 7E7 875 059 K UV8
Blue: 7E7 875 059 K UR7
Red: 7E7 875 059K UW9
Thank you all for your replies - very helpful.
The leisure batteries fitted by VW are Varta LA80 batteries. A lead/acid AGM battery.
The Varta F21 is fitted as the engine battery.
Both batteries are the same size with similar specifications but sold for different purposes but are interchangeable. The F21 is often cheaper than the LA80. Some members have fitted the cheaper F21.
