Amarillo
Tom
We used a in spainI'd have thought A
Seen both abroad , so I would take both to be safe
I always carry B in the safe for emergencies. I think Italy has a lot of them still.
I'm surprised that you don't have a reversed polarity lead; still quite a common occurrence on continental sites.Anyway, I have four adaptors or leads.
I’m not sure it matters on any of the appliances we use: kettle and hot plate. We’ve used a small fan heater in the awning on a couple of occasions. Other than that everything is 12v DC and reverse polarity won’t affect the battery charger.I'm surprised that you don't have a reversed polarity lead; still quite a common occurrence on continental sites.
If we had a toaster it would be very dangerous if someone poked in a knife without unplugging.
Same as touching the element on electric fan heater with something metallic.
Its the only time that a reverse polarity is more dangerous.
You would have to be pretty stupid to do either.
The campsite in Spain says:
"Electric connection: Blue European plug for exterior. Adaptor required."
Is that this
Or this
A. B is used in Morocco. May be other countries too but I stick to Morocco.The campsite in Spain says:
Is that this
Or this
