SamSara
Sent twice and missed off thank you for your time, I need to get out
It's pouring with rain here.Thank you for taking the time for this on such a lovely day
Same in my T6....
The Amperage (A) in the screen of the central unit shows zero, and that is correct: if you connect the solar directly to the plus and minus poles of the battery, the central unit does not see that you are loading ( at least in my T5, don’t know exactly how the unit behaves in your T6).
Regards from Amsterdam,
Marc.
Thank you I will try again tomorrow. It clouded over and started raining here, just as I got out on the water for a paddleAs WG said, the bat seems to be already topped up to the brim.
You could disconnect the solar, then put a 100 Watt light in the inverter, to suck some energy out of the battery. You should see the voltage going down a little bit. Then wait a couple of minutes to calm the batt down, and only then reconnect the solar to the batt. If the voltage in the screen of the central unit is rising again, you’re ok.
Marc.
When it’s sunny, run the fridge or Parking Heater to put a significant load on the Leisure Batteries and after 30 mins connect the Solar system.Thank you I will try again tomorrow. It clouded over and started raining here, just as I got out on the water for a paddle
Cover just pulls off, it's easy... Just roll the passenger seat forward... It will take you seconds to get to the terminals.Havent tried the crocodile clips yet,because it looked such a faff to get the cover off to the battery. kit the same as video
I see I was late in that post... From your photos I can't see how you have connected up to the controller... From memory, the solar panel is the left socket, the battery is the middle socket... You can see the wiring in my video.. I'm sure that's how you have it but just checking.... My van display does show ampage when charging (at least via socket) but my display is different as I have a t6.1... I think you need to drain the battery a bit like others said, turn the fridge on max for a few hours. Then try it.. If you are near or coming near Westerham then I'm happy to have a look, you can contact me via markheathcote.com via the contact form.Cover just pulls off, it's easy... Just roll the passenger seat forward... It will take you seconds to get to the terminals.
Also, sits a phone charge using the USB socket on the side of the controller box? If it charges the phone then you know it is working, at least out of the 5v usbI see I was late in that post... From your photos I can't see how you have connected up to the controller... From memory, the solar panel is the left socket, the battery is the middle socket... You can see the wiring in my video.. I'm sure that's how you have it but just checking.... My van display does show ampage when charging (at least via socket) but my display is different as I have a t6.1... I think you need to drain the battery a bit like others said, turn the fridge on max for a few hours. Then try it.. If you are near or coming near Westerham then I'm happy to have a look, you can contact me via markheathcote.com via the contact form.
Hmm, my 6.1 display does show ampage coming in, though that's by the 12-volt cigarette socket which I would have thought would be the same as connecting directly to the battery... Not tested the display via crocodile clips but don't see why it would differ. Maybe the 6.1 has some upgraded system.Same in my T6.
The current measurement is made via a shunt which is placed between the negative pole of the leisure battery and the chassis.Hmm, my 6.1 display does show ampage coming in, though that's by the 12-volt cigarette socket which I would have thought would be the same as connecting directly to the battery... Not tested the display via crocodile clips but don't see why it would differ. Maybe the 6.1 has some upgraded system.
I have found this one to perform really well. Super easy to set up, fits upright on the back shelf of the Cali. Its much lighter than those folding suitcase type panels. It produces what the advertising says and the quality is spot on. https://amzn.to/3OomKqaHi, i want a solar panel to extend or life for a few more days. So ,any to choose from i would appreciate guidance. I do not want one on the van and i would like ease of setting up.
thanks
Using the cig lighter socket is no different to wiring direct to the battery except the cig lighter has a10amp fuse inline, hence you need to make sure the controller doesn't exceed 10 amp out. Caveat, not to be done by someone that isn't sure of what they are doing, but it's not dangerous you'll just blow a fuse if you exceed 10amps. You must always use a charge controller though.I now use a RidgeMonkey fold-up 80w solar panel that charges the leisure batteries via a victory charge controller. It was happily pumping out 55w in full sun last Friday (250wh over about 6 hours). https://ridgemonkey.co.uk/product/vault-c-smart-pd-80w-solar-panel
Charging via the cigarette lighter sounds like an expensive and potentially dangerous accident waiting to happen.
I’ve also tried a roof mounted panel but that failed after about 18 months and damaged the roof too (to my mind it wasn’t fitted properly- even though I paid to get it done ‘professionally’). I have a replacement panel kit from Solar Camper Solutions but I’ve decided not to fit it. If you want it, pm me with a sensible offer and it’s yours!
You mentionned you have a damaged panel waiting to be picked-up. Maybe you can try using the charge controller of this damaged panel to rule out an issue with the charge controller?Thank you I will try again tomorrow. It clouded over and started raining here, just as I got out on the water for a paddle
Hi, Where did you get this from? And how much?Have also just fitted a semi-permanent 100w panel (just bolts to roof rails). Easy installation and works brilliantly. View attachment 91624
I would say that is mostly made to charge Jackerys own batteries? Its a bit expensive and overkill to just connect a usb-a device and a ”non pd” usb-c device?I have found this one to perform really well. Super easy to set up, fits upright on the back shelf of the Cali. Its much lighter than those folding suitcase type panels. It produces what the advertising says and the quality is spot on. https://amzn.to/3OomKqa
You can use the solar without connecting to van, as the charge controller has built in usbs. Just plug a phone or iPad in and you will then prove the panel is workingThank for all advice. I had a go yesterday, but it was too cloudy and rained. I think it is working. Showed 12.5v after fridge on full then 12.6 when solar went on via cig lighter then after 20 minutes (rain started) 12.7v
The USB is just a bonus feature that we dont really need.I would say that is mostly made to charge Jackerys own batteries? Its a bit expensive an8d overkill to just connect a usb-a device and a ”non pd” usb-c device?
I have a brand new one for sale if you’re interested. It’s made by Solar Camper Solutions. I live in Bristol too - so quite close to you. To get my contact details email me at selling.ufvqw@simplelogin.coHi, Where did you get this from? And how much?
Very nice, you don't have to make the 12v lead... There is a link to one from the US via amazon that took v3 days tobarrive and was cheap. You can find the link on the video I posted, here again, or at thehuntercrew.com... We don't get any commission on that lead, but I can recommend it...Happy so far with my 100w Dokio set up. I haven’t got around to making a lighter plug lead for it yet, just clipped it onto the underseat battery for now. It’s hot here so the fridge is working pretty hard, and it’s nice not worrying about turning lights off etc, although I’m still charging devices off a Jackery.
Of the claimed 100w I’m seeing around 60 at noon and 20 now the sun is on the other side of the van, but I’m not going to sweat it - the charge indicator in the van hasn’t dropped from full all day. I’ve got some wee hooks to hang the panel from the awning rails if needed.
Winter use might be a different story with less light and running the heater, but that time of year we’re generally not away for more than a long weekend.
Not sure it’s worth making the lighter plug connectors - I’ll maybe just connect to the battery with ring terminals and velcro the controller to the seat base.
