Missing relay!
G
Grand Cali Pete
Cheshire
Grand California 680
Hi all,
I seem to have a relay missing in the power cupboard. Other posters have pictures with all the relay bases populated.
can’t make head nor tail of the wiring diagrams to tell what its for! Any ideas?4A32C328-4AD3-4223-A2E3-A2F536826F83.jpeg
Can‘t help with what they are all for but this is ours… I’d say that you are missing a few - maybe depending on your options…1676812882139.png
Hi all,
Relay position second in from left is a light control relay, 5th from left is consumer switch off relay and far right end is relay for deactivating in event of a crash.
All looks a bit sparse.
What age/spec details do you have for your GC?
You’ve also got an extra one “646” which doesn’t get mentioned in the wiring layout I’ve seen.
It was first registered in March 2020 and I was a little surprised that it had euro shuko sockets instead of UK 3 pin type. When I had it checked out by hpi and experian, everything came back ok. So I changed the sockets and have been trying to get to grips with the electrics. Spec seems quite good with ambient lighting, Wi-Fi etc and it’s only done 2500 miles.
Sounds like an early model if it came with EU sockets. Possibly even been one of the press vehicles.
Might be that the wiring has changed since then, the info I have seen matches what I have and as posted above.
I guess if all is working then it’s ok?!
Thanks for the help. I was told by the previous owner that it was a demonstrator. I think the 646 relay is the fuel control. Everything works ok. Had the step issue today, which following the advice on the forum was quickly sorted(blue plug).
